Importing standard data as ASCII DAT file from a database in csv
Started by Alejandro Cortes, November 07, 2024, 03:59:33 AM
Alejandro Cortes
Hi everyone,
We recently installed PfE at NHM in London. Although the Standard app has an option to load standard info from JEOL, the JEOL files do not have as much info as I would like to them to include. So, I did a python script that I am happy to share here if somebody wants to use it. It is based on the way we are now storing standard data at NHM, but can be easily adjusted if needed (tried to comment the script in the best way possible). If you find any issue let me know.
I think attaching a script might be flagged, so I just copy-paste it here.
Edit by John to paste script into a code control:
# This python script helps extracting information from a standard database in csv format
# then the data is written in the format that can be read by PfE
# Example of Standard Format in PfE ASCII .DAT File:
# This block explains the format of the ASCII .DAT file that the script generates.
# 100            "Calcite"          : std number in PfE, standard name in ""
# "CaCO3"                            : the following six lines are just additional standard info
# Locality: WealGrey_Cornwall
# ID_EPMA: A01
# ID_EPMA2: CAL2_221
# BM: BM32890
# Reference: ChemLab_11076"
# -1            8                  : flag to calculate as oxides (-1) or as elements (0),
#                                      the number of elements in the standard
# 2.71                              : standard density
#    "Mg"  "O"  "Ca"  "P"  "Fe"  "Mn"  "Ti"  "C"                : list of elements in the standard in ""
#      1      1      1      2      1      1      1      1      : cations in oxide or 1 if element
#      1      0      1      5      1      1      2      2    : oxygens in oxide or 0 if element
#  0.082  47.960  37.450  0.017  0.024  0.996  0.022  12.000  : element wt.% in the standard
# "Carbonate"        0            0            ""            "3"      : standard type in "", -1 calculate formula/ 0 doesn't,
#        number of cations per formula unit (cat p.f.u), formulas,
#        and standard block in ""
#        (Note: formula calculations are not included in this code, so these values are set to 0)
# Example of NHM Standard Database CSV Structure:
# The CSV structure should include the following columns but they can be changed accordingly:
# Name, Formula, Density, ID_EPMA, ID_PfE, ID_Old, BM, Type, Block, Locality, Reference, Mg... (and other elements)
# Example entry (for Calcite):
# Calcite,CaCO3,2.71,A01,100,CAL2_221,BM32890,Carbonate,3,WealGrey_Cornwall,ChemLab_11076,0.0816
# Example entry (for Chromium):
# Chromium,Cr,7.19,B01,101,PCR_117,Element,6,Synthetic,ChemLab
# When there is no reported information or value for an argument, it will be shown as empty (which is read as NaN).
#libraries needed to run the script. This is to creade dataframes
import pandas as pd
# Function: convert_ascii_std
# Purpose: Converts a single row of standard data into a PfE-readable ASCII .DAT format.
# Arguments:
#  - row: The row containing standard information from the input CSV.
#  - element_composition: A list of column names representing element compositions (weight %).
#  - cat: A series representing the number of cations for each element.
#  - oxy: A series representing the number of oxygens for each element.
# Returns:
#  - A formatted string containing the .DAT content for a single standard entry.
def convert_ascii_std(row, element_composition, cat, oxy):
    # --- Extract Standard Metadata ---
    name = row["Name"]              # Name of the standard
    formula = row["Formula"]        # Formula of the standard
    density = row["Density"]        # Density of the standard
    id_pfe = row["ID_PfE"]          # Standard number in PfE
    id_EPMA = row["ID_EPMA"]        # EPMA ID of the standard
    id_Old = row["ID_Old"]          # Old ID (if available)
    BM = row["BM"]                  # Museum entry number (if applicable)
    type = row["Type"]              # Type of standard (e.g., carbonate, silicate, etc.)
    block = row["Block"]            # Block number in the database
    locality = row["Locality"]      # Locality or source of the standard
    reference = row["Reference"]    # Reference or source information
    # --- Extract Element Composition Data ---
    wt_Element = row[element_composition]  # Weight percentages of elements in the standard
    # Remove elements that have zero values in the weight percent (i.e., ignore them)
    non_zero_elements = wt_Element[wt_Element > 0]
    # --- Filter Cations and Oxygens for Non-Zero Elements ---
    cat_clean = cat[wt_Element > 0]  # Corresponding cation values for non-zero elements
    oxy_clean = oxy[wt_Element > 0]  # Corresponding oxygen values for non-zero elements
    # --- Determine Flag for Oxides vs Elements ---
    display_ox = -1 if "O" in row and row["O"] > 0 else 0  # Flag: -1 for oxides, 0 for elements
    # --- Count Non-Zero Elements ---
    elements_shown = len(non_zero_elements)  # Number of elements with non-zero weight percentages
    # --- Generate Element Symbols List ---
    element_symbols = [f'"{elem}"' for elem in non_zero_elements.index]  # List of element symbols for non-zero elements
    # --- Generate Element Content Data ---
    element_content = [f'{val:.3f}' for val in non_zero_elements]  # Weight % of each element formatted to 3 decimals
    cat_values = [f'{val}' for val in cat_clean]  # Cation values
    oxy_values = [f'{val}' for val in oxy_clean]  # Oxygen values
    # --- Construct ASCII .DAT Content ---
    output = f'''
{id_pfe}            "{name}"
"{formula}
Locality: {locality}
ID_EPMA: {id_EPMA}
ID_EPMA2: {id_Old}
BM: {BM}
Reference: {reference}"
{display_ox}            {elements_shown}
{density:.2f}
    # Add the element symbols (e.g., "Mg", "Ca", etc.)
    output += "  " + "  ".join(element_symbols) + "\n"
    # Add the corresponding cations for the elements
    output += "      " + "      ".join(cat_values) + "\n"
    # Add the corresponding oxygens for the elements
    output += "      " + "      ".join(oxy_values) + "\n"
    # Add the weight % content for the elements
    output += "  " + "  ".join(element_content) + "\n"
    # Add additional standard details (e.g., type, formula, block)
    output += f'"{type}"        0            0            "{formula}"            "{block}"'
    return output
# Function: process_csv
# Purpose: Reads an input CSV file and generates a single .DAT file for each standard.
# Arguments:
#  - input_csv: Path to the input CSV file containing the standard information.
#  - output_file: Path to the output .DAT file where the converted data will be saved.
#  - catox_csv: Path to the CSV file containing cation and oxygen data for each element.
def process_csv(input_csv, output_file, catox_csv):
    # --- Read Input CSV Files ---
    df = pd.read_csv(input_csv)  # Standard information CSV (contains name, formula, etc.)
    dfcatoxy = pd.read_csv(catox_csv)  # Cation and oxygen data CSV (contains element cations and oxygens)
    # --- Identify Element Composition Columns ---
    element_composition = df.columns[11:]  # The columns containing the element composition data (adjust if needed)
    # --- Extract Cation and Oxygen Data ---
    cat = dfcatoxy.iloc
[o]  # Cation values (first row of the cation/oxygen file)
    oxy = dfcatoxy.iloc[1]  # Oxygen values (second row of the cation/oxygen file)
    # --- Open Output File for Writing ---
    with open(output_file, 'w') as out_file:
        # Iterate over each row in the DataFrame and convert to ASCII format
        for idx, row in df.iterrows():
            # Generate the .DAT content for the current row
            dat_content = convert_ascii_std(row, element_composition, cat, oxy)
            # Write the generated content to the output file
            out_file.write(dat_content)
    # --- Remove First Blank Line ---
    # This step removes the first blank line that may cause issues when reading the file in PfE
    with open(output_file, 'r') as file:
        lines = file.readlines()
    with open(output_file, 'w') as file:
        file.writelines(lines[1:])  # Rewrite the file without the first blank line
    print(f"Generated {output_file} with the first line removed")
# Main Execution Block
# Purpose: Process the input CSV and generate the output .DAT file for PfE.
# Define input and output file paths
input_csv = 'EPMA_Standards.csv'  # Replace with the actual file path to your standard CSV
catox_csv = 'cat_ox.csv'  # Replace with the actual file path to your cation/oxygen data CSV
output_file = 'standardsforPfE.dat'  # Output file name for the converted .DAT file
# Process the CSV and generate the .DAT file
Alejandro's script above is very nice, but if you only want to just import the compositional data from your current Cameca or JEOL standard compositions (and any other available fields), you can simply utilize one of these two menus in the Standard application:
See also appendix A or B in the attached pdf.
