Casino 3.3.0.4 and SEs - continued
Started by amit, April 21, 2026, 09:44:57 AM
amit
Hi everyone,
I was thinking initially that I could see the SEs Casino (v3.3.0.4). At least on the visual level in the program itself, I understand that this is not the case
Question No. 1: Am I wrong?
Then, I saved the data into the .dat file, which shows many trajectories. Next to most of them I see "secondary electron". I am not sure, then, what this trajectory is. Is it the primary's trajectory and each of those labeled with "SE" means it created one?
Question No. 2: Am I correct in my understanding?
Finally, even if I see tons of "secondary electron" labels in the .dat file, the SE yield on the GUI shows zero. And so I am more perplexed.
Question No. 3: What do the different colors in the distribution plot of the electrons signify? This is not well documented.
Question No. 4: Why is the SE yield zero?
Thanks for your help.
Amit
zhlltu2026
you will see the secondary electrons in the simulation result trajectory display as long as the tracking SE in enabled, the blue trajectories are primary electrons, the red ones are backscattered electrons escaped out of surface, and you can see many short trajectories with green color along the primary trajectories, which are secondary electrons.
I could be wrong, but my understanding is that the SE yield only counts the SEs escaped out of the surface.
zhlltu2026
amit
amit
Quote from: zhlltu2026 on April 27, 2026, 06:33:18 AMyou will see the secondary electrons in the simulation result trajectory display as long as the tracking SE in enabled, the blue trajectories are primary electrons, the red ones are backscattered electrons escaped out of surface, and you can see many short trajectories with green color along the primary trajectories, which are secondary electrons.
zhlltu2026
And on the same topic, if I look at the exported data file, for example:
"Trajectory"   22902
"Type : "
   Secondary Electron
"Collisions"
"X"   "Y"   "Z"   "Rx"   "Ry"   "Rz"   "Energy"   "CollisionType"
61047.4   -140568   -49564.7   0.619957   -0.611033   -0.492231   0.00511574033763   Atom
61047.4   -140568   -49564.7   0.762161   0.328753   -0.557702   0.0051028095138   Atom
61047.6   -140568   -49564.8   0.762161   0.328753   -0.557702   0.005   Atom
Do you know what is the delta in time between each line of the trajectory? Or is this straight-forward by taking the coordinates themselves?
amit
Two more questions:
(1) When simulating 50 primary electrons instead of 1, does Casino simulate all of them in one go (simultaneously, i.e., a beam of 50 electrons) or does it simulate them one after the other?
(2) Is there a maximal bound on the energy of the primary electron? Will it complain if I try a very high energy? Won't relativistic effects take place then?
Amit
hdemers
QuoteAnd on the same topic, if I look at the exported data file, for example:
"Trajectory"   22902
"Type : "
   Secondary Electron
"Collisions"
Hi amit,
Casino does not calculate the time between collision. I guess you can calculate it with the energy and the distance travelled. But I never try it.
Regards,
Hendrix
hdemers
Quote from: amit on May 03, 2026, 06:25:11 AMTwo more questions:
Amit
Hi Amit,
CASINO simulate each trajectory one after one. If you simulate multiple scan points to get an image, it will use multicore to simulate scan point in parallel.
The model take in account the relativistic effect. I don't remember if a upper bound on the energy of the primary electron. The tabulated models has an energy range, but the numerical model may not have energy range. If I remember correctly I have tested CASINO up to 500kV.
Regards,
Hendrix
