Fe Ll mac
Started by Ben Buse, August 01, 2017, 05:10:17 AM
I notice in PFE the FFAST mac Fe Ll in Fe is listed as 2610.3 whilst in Gopon's paper its listed as 2765 for FFAST - any ideas which is right?
In Calczaf Fe Ll Fe is a typo  its listed as 12092.77 which is Fe Lb in Fe
Quote from: Ben Buse on August 01, 2017, 05:10:17 AM
When I use my polynomial interpolation program, I get mu/rho = 2614 cm2/g for X-ray energy = 615.2 eV (from Bearden) in pure Fe.  I can send you a copy of the program if you want.
Brian
Hi Brian,
Thanks for confirming that, yes it be good to have a copy of the program (I'll send you an email)
I've just checked and in calczaf program - the quantification uses the correct MAC like PFE - its just the displayed mac - i.e. when you click 'display emitter absorber pair' . Oddly enough not when you click show MAC table - here its correct.
Quote from: Ben Buse on August 02, 2017, 11:35:12 PM
Good catch.
It's just a display issue for that menu, which I have already fixed and will upload later today.
Thanks.
Quote from: John Donovan on August 03, 2017, 08:39:11 AM
Good catch.
Thanks.
The latest CalcZAF 11.9.6 is fixed for this display issue and ready to download.  Note that because I didn't bump the version number you should run the update/install twice, the 2nd time being a "repair" to get the updated exe.
Thanks, correct mac displayed
Quote from: Ben Buse on August 07, 2017, 10:58:01 AM
Since I bumped the version number to 11.9.7 this weekend, one does not need to run the installer twice.
