Image Locator Feature
Started by John Donovan, May 23, 2018, 02:52:00 PM
I love the image locator option! Would it be possible to also have probeimage files be supported? I figured out that I can open the prbimg files in CalcImage and export as calibrated bmp but it would be cool to import them directly instead of having to go through CalcImage.
Also, is it possible to batch import the files. I seem to be only able to import them one by one?
Quote from: Anette von der Handt on September 07, 2022, 01:10:40 PM
Thanks.  It is a pretty cool feature.  For those who aren't familiar with it, here's an example:
https://smf.probesoftware.com/index.php?topic=1082.msg7245#msg7245
We will take a look and see if we can add these changes for you.
Quote from: John Donovan on September 10, 2022, 07:49:12 AM
Really, sorry. We seem to have forgotten about these two requests and will get to them as soon as we get a chance.  We've been working the last three months on a major release of Probe for EPMA with a bunch of cool, new features...
The latest version of PictureSnapApp now warns you if the aspect ratio of the selected image (in the Image Locator window) is not the same as the aspect ratio defined in the Stage Configuration dialog.
If the aspect ratio of the remote image is different than the specified aspect ratio, the software allows the user to still load the image and adjusts the stage calibration (still centered on the current stage position), but it assumes the x axis dimension of the image is still calibrated to the 100x FOV distance as defined in the Stage Calibration dialog.
