Re: Xmac
Started by Ben Buse, March 29, 2017, 10:28:19 AM
Does anyone know if its possible to change the MAC when quantifying k-ratios. What I'd like to do is write a script to adjust the MAC finding the best fit to data collected at multiple voltages - to experimentally measure the MAC.
Quote from: Ben Buse on March 29, 2017, 10:28:19 AM
I don't know about DTSA-II, but what you describe is exactly what Pouchou's XMAC software does.
Quote from: Probeman on March 29, 2017, 10:40:40 AM
How is XMAC software distributed? Is it part of SAMX XMAS or a seperate SAMX package - I can't see it in the 2002 version
Also does anyone have a copy of the following paper - which I think explains the method
POUCHOU, J.L. & PICHOIR, F. (1988). A simplified version of the
"PAP" model for matrix corrections in EPMA. In Microbeam
Analysis, Newbury, D.E. (Ed.), pp. 319–324. San Francisco, CA:
San Francisco Press
Quote from: Ben Buse on July 26, 2017, 05:23:34 AM
San Francisco Press
Yes, XMAC is part of the SAMx STRATAGem package.
If you do a search of "XMAC" on this forum you'll see several mentions, for example:
http://smf.probesoftware.com/index.php?topic=667.msg4064#msg4064
JohnF
Quote from: Probeman on July 26, 2017, 07:57:31 AM
San Francisco Press
John and all: Actually you do not need to have the (nice but expensive StrataGEM or other) SamX software. The application is standalone (with everything needed to execute, albeit on older PCs) and apparently licensed to Pouchou and ONERA. I have a zipped version on my EPMA class software web page, which can be downloaded.
Go to: http://www.geology.wisc.edu/~johnf/g777/777Software.html
It's at the bottom. Also there is gmrfilm (Waldo's thin film DOS software).
John
Probing
Quote from: JohnF on August 03, 2017, 02:34:49 PM
San Francisco Press
John
The link has been invalid. Could you upload the file back to your server?
Dylan
Quote from: Probing on June 27, 2023, 07:58:57 PM
San Francisco Press
John
Dylan
What link are you talking about?
If you are looking for Xmac that is commercial software and cannot be distributed, but you can do the same calculation for mass absorption coefficients from experimental intensities as Xmac, using the new BadgerFilm I think.
https://smf.probesoftware.com/index.php?board=37.0
Probing
Quote from: Probeman on June 27, 2023, 08:30:28 PM
San Francisco Press
John
Dylan
Thank you, John. I will try the BadgerFilm.
