Latest version changes for Probe for EPMA (and CalcImage) v. 14.2.8
Started by John Donovan, August 17, 2013, 12:58:53 PM
AndrewLocock
Quote from: John Donovan on September 19, 2023, 02:01:47 PMContinuing with changes since June, we added a new backscatter correction called the DAM (Donovan and  Moy) backscatter correction as described in the latest version.txt file:
[tt]07/29/23    Add new matrix correction code for Donovan and Moy BSC/BKS corrections (modified from PAP).
[/tt]
This deserves its own topic here:
https://smf.probesoftware.com/index.php?topic=1566.msg12044#msg12044
Why did we name it the DAM backscatter correction?  Well. perhaps because that was better than the MAD backscatter correction...    :D
Be sure to update your Probe for EPMA using the Help menu as we had to make some minor tweaks (today) to fix some display issues.
Hello,
The attached screen capture (JPG) shows a comparison for the NIST Au-Ag SRMs 481C,D,E of the various matrix corrections, using LINEMU / CITZMU.
The sum of the squared differences for both Ag and Au were computed with respect to the average mass fractions given by NIST.
For this system, the PAP/Donovan and Moy BSC/BKS (prZ) scheme gives the lowest mean squared differences.
Thanks for the improvement!
P.S. Operating conditions: 15 kV, 20 nA, 5-micron beam diameter, 60 s on peak, Cameca SX100, Au M-alpha, Ag L-alpha lines, n = 8 points each.
AndrewYou cannot view this attachment.
Very nice.
Yes, the Z based corrections are a definite improvement, especially for such high Z materials where the A/Z ratios are significantly different for these elements.
If interested, one can see these differences using the Standard application. Simply check the Output | Calculate Alternative Zbars menu, double-click a standard in the list and you will see this output:
The original paper is here from 2023:
https://academic.oup.com/mam/article-abstract/29/4/1436/7224307
and a followup (2024) is here:
https://academic.oup.com/mam/article/30/Supplement_1/ozae044.088/7719396
AndrewLocock
Can we look forward to a publication on the DAM matrix corrections?
Thanks again,
Andrew
The paper links in my previous reply should suffice. But if anyone is interested in the actual code, see here:
The changes are noted in the ZAF.BAS module.
AndrewLocock
Donovan, J., Ducharme, A., Schwab, J.J., Moy, A., Gainsforth, Z., Wade, B. and McMorran, B., 2023. An improved average atomic number calculation for estimating backscatter and continuum production in compounds. Microscopy and Microanalysis, 29(4), pp.1436-1449.
The latest version of Probe for EPMA (v. 13.9.5) now includes a new "helper" dialog called Advanced EPMA, which is similar to the existing Basic EPMA dialog:
https://smf.probesoftware.com/index.php?topic=1267.0
which provides one click access to various advanced methods and functions in Probe for EPMA, along with links to context sensitive Help and links to video tutorials on our Probe Software YouTube channel:
You can access both of these "helper" dialogs from the File menu in Probe for EPMA, once a new probe database is created or an old probe database is opened.
You will note that some methods and functions do not yet have video tutorials but we hope to provide them in future updates.  If you are interested in producing video tutorials for Probe Software on specific topics, as seen here:
https://smf.probesoftware.com/index.php?topic=1578.msg12220#msg12220
We do provide compensation for your time, so please contact Probe Software directly by email.
The current version of Probe for EPMA is 13.9.7.  We've fixed a number of small bugs and added some new features as described here:
https://smf.probesoftware.com/index.php?topic=40.0
After updating Probe for EPMA please check that you are on v. 13.9.7 by checking the Help | About Probe for EPMA menu dialog.  If you are not, please update again using the Help | Update Probe for EPMA menu.  If it says you are already on the latest version but you are not on v. 13.9.7., please click the Delete Update button in the Update dialog to force an update to v. 13.9.7.  This update issue may be due to our transition over to a new Internet host this fall, but once you are updated to v. 13.9.7 you should be fine for future updates.
Happy New Year!
Last summer we had to move our Probe Software web and server hosting to a new provider. We did keep the old site up for a while to allow people to get their current software updated, but eventually we had to change things to the new server which came with new security protocols.
So if you have an old version of Probe for EPMA from 2024 (or older), you will need to utilize the secondary download site here in your current software using the Help menu in CalcZAF and/or Probe for EPMA:
Once you are updated with CalcZAF and/or Probe for EPMA, you will have v. 14.0.2 and the Help | Update window will have changed to this:
Or you can download the latest CalcZAF and/or Probe for EPMA here on our Resource page:
Note that for new installations for re-processing data from your instrument, or running Probe for EPMA in simulation mode on a new computer, you need to download and install both the CalcZAF and Probe for EPMA MSI installers as mentioned on the web page.
I'm pulling the above post forward because we've had a few people say they can't update to the latest v. 14.0.x of Probe for EPMA.
It's because our old hosting site can no longer be updated, so if you're trying to update your Probe for EPMA software version 13.9.x from before October 2024, you'll need to update from the secondary download option as described above.
Once updated to v. 14.0.x you'll be able to use the default download site again (Probe Software).
Alternatively one can update from our Resources page:
See download buttons near the bottom of the page.
We improved the behavior of the shift and zoom spin controls in the Plot! wavescan dialog (and also the Output | Output Standard and Unknown XY Plots menu dialog) when the graph is already "zoomed":
So one can now perform shifting and zooming on your graphs using either the click and drag mouse method or the spin button controls.
We've added three new video tutorials from our Probe Software YouTube channel:
https://www.youtube.com/@ProbeSoftware
to the Advanced EPMA "helper" window in Probe for EPMA (see under the File menu):
These include short tutorials how to acquire MAN background standards, perform quantitative spectral interference corrections and how to specify blank corrections for improved trace element accuracy.
We made a small, but possibly interesting, change to Probe for EPMA.
We added a new method for setting the beam current on modern JEOL instruments (8230/8530/iSP100/iHP200F) that utilizes a direct TCP/IP command to the instrument. That is, it does not utilize the JEOL EIKS interface.
To use this new direct command, edit your Probewin.ini file for the BeamCurrentType keyword:
[hardware]
BeamCurrentType=2
Note that this command returns immediately, but it does need around 10 seconds or more to properly set the beam current.  Therefore, in addition, you will need to edit the following keyword also:
[software]
BeamCurrentChangeDelay=10
Testing by our most excellent beta testers, finds that the length of time varies, but at least 10 seconds or so is required.
Update as usual from the Help menu in Probe for EPMA to v. 14.2.6 and try it out for yourselves!
We added a link to the YouTube video on WDS dead time calibrations to the Advanced EPMA window (accessed from the Probe for EPMA File menu), using the constant k-ratio method:
More details can be found here also:
https://smf.probesoftware.com/index.php?topic=1466.msg11102#msg11102
