Is it possible to export with data whether using high only, linear, low only, slope etc and amount of slope. Also is it possible to export with data which blank correction standard your using? Or could this be implemented?
Quote from: Ben Buse on November 13, 2026, 02:34:23 AMIs it possible to export with data whether using high only, linear, low only, slope etc and amount of slope. Also is it possible to export with data which blank correction standard your using? Or could this be implemented?
I would look in two places. First the Report button output in the Analyze! window. That will output sentences describing the analytical conditions for use in publication/documentation but also a tab delimited text file for tables.
https://smf.probesoftware.com/index.php?topic=8.msg8398#msg8398
The other is the User Specified Custom output where you can select all sorts of output types.  This dialog is accessed from the Analyze! window by right clicking the sample list and also the Output menu:
https://smf.probesoftware.com/index.php?topic=1317.msg9471#msg9471
Quote from: John Donovan on November 13, 2026, 07:23:32 AM
For example:
and
