Cameca Driver Latest Version
Started by Philipp Poeml, October 31, 2013, 02:36:49 AM
What is the latest psi_sx100.dll version? I have a 1.7.0.213 here, in one of your posts I saw you have a 1.8.0.222 around.
Am I missing something?
Philipp
The latest version of the SX100/SXFive driver is 1.8.0 but it is simply an internal change with no external features.  I can send it to you and you can check the Readme file if you like.
To install the new Cameca SX100/SXFive driver simply unzip the file and copy the psi_sx100.dll to the Windows system folder as described here:
Windows XP:             Windows\System32
Windows Vista 32:       Windows\System32
Windows Vista 64:       Windows\SysWOW64
Windows 7 32:           Windows\System32
Windows 7 64:           Windows\SysWOW64
The latst Cameca driver is 1.9.0 and can be obtained from Probe Software for free.
It now supports the new PHA MCA acquisition capability in SX100 and SXFive instruments as described here:
http://smf.probesoftware.com/index.php?topic=42.msg883#msg883
Can I please get a copy of the latest driver? I keep getting the message box popping up upon connecting to hardware telling me I need to update it.
Edit by John: it is sent by email attachment.
Latest Cameca SX100/SXFive driver version is 2.0.0.
Version 2.0.0 - 28-Jun-2014
  - Changes to the log generation to be more Windows 7 (and later) compatible. Log
    files are now created in the users Documents location instead of the folder that
    holds the executable (this folder may not be writeable). Log file name will be
    generated from the app name as - <appname>_SX100.log
  - Improvements to the build system
Latest version of the Cameca SX100/SXFive driver is 2.02.  Contact Probe Software for an updated driver.
What's New
Version 2.0.2 - 25-Mar-2015
  - Cleanup of bug in new initialization code.
Version 2.0.1 - 15-Mar-2015
  - Cleanup of some of the initialization code.
    holds the executable (this folder ma not be writeable). Log file name will be
Remember,  If you install v. 11.x of Probe for EPMA on a new computer you *must* utilize version 2.0.3 of the Cameca (or  JEOL) driver!
What's New
Version 2.0.3 - 25-Aug-2015
  - Added support for Probe for EPMA's new common app data folder for
    initialization parameters.
