Turn off a spectrometer
Started by glennpoirier, February 26, 2018, 05:49:39 AM
glennpoirier
Hi All,
I'm sure I've seen this on the forum somewhere but do you think I can find it? I have on spectrometer currently not working and the probe thinks its current position is 454 mm(!). PFE thinks this is obviously wrong and shuts down with a warning. Is there a way to temporarily tell PFE to ignore this spectrometer?
Glenn
Quote from: glennpoirier on February 26, 2018, 05:49:39 AM
Hi All,
Hi Glenn,
Sorry your instrument isn't feeling well!   :)
Just edit this keyword for the bad spectrometer number in the [hardware] section of your probewin.ini file until the spectrometer is repaired:
DisableSpectrometerNumber=0      ; disable spectrometer flag allows a single spectrometer to be ignored by the program
glennpoirier
Thanks for the quick response, should have looked harder! This is what I was looking for but unfortunately it doesn't do what I need.
When PFE first starts I get the following message:
Warning spectrometer 1 is disabled for all real time operations!
Then I'm asked if I want to connect to the microprobe, I say yes and then i Get the message below and PFE exits.
I'm trying to find out how to enter an arbitrary position in the JEOL software but in the meantime is there anything else I can try on the PFE side?
Glenn
Quote from: glennpoirier on February 26, 2018, 08:06:03 AM
Hi Glenn,
Clearly we haven't tested this spectro disable feature for some time!
I'll need to tweak the code to skip this spectrometer during the initialization.
Give me a few minutes and I get back to you.
glennpoirier
All better now, it just ignores the position of the disabled spectrometer.
Thanks for the rapid response! On with the analyses!
Glenn
