phi-rho-z curves and changing emission images
Started by Walter, February 12, 2019, 07:33:20 AM
Walter
Hi everyone,
Do you know if in DTSA2 is possible to obtain the phi-rho-z curve of a specific element after a simulation? For now the only idea I have is to use a image processing software (like Imagej) and extract the data from the lateral bars in the emission images.
Then I'd like to know if it is possible to change the size/resolution, scale and colors of the output emission images.
Thank you,
Walter.
Hi Walter,
I guess you've read here
https://smf.probesoftware.com/index.php?topic=965.msg6275#msg6275
currently the only way to generate phi-rho-z curves is before hand using the script.
The emission images, will only give emission phi-rho-z, not generated
