GMT (Generic mapping tools)
Started by Ben Buse, October 17, 2019, 03:35:22 AM
Has anyone used GMT generic mapping tools
http://gmt.soest.hawaii.edu/
With three lines of code I can create a ps or pdf file from a surfer grid file
The first line sets up the color scale, starting at 0 to 5000
gmt makecpt -T-0/5000 > compo.cpt
The second line plots the map [B5 sets tick marks on axis every five units, for above image I used B0.05]:
gmt grdimage 1-5_00006_COMPO.grd -JX6i+ -I -B5 -Ccompo.cpt -K > COMPO4.pdf
The third line plots the color intensity scale:
gmt psscale -Ccompo.cpt -Dx6.5i/15c+w12c/0.5c+jTC -Bx1000 -O >> COMPO4.pdf
Does anyone know if its possible to plot a distance scale bar, or is it not possible without geographic projection. Also I've yet to figure out how to label axes.
I've slightly progressed this. This time running on windows. A cmd batch which pass files to in command prompt window
In command prompt window
1. use cd to change to directory where want to save
2. drag batch file into window, type space, drag grd map files into window
:: change in cmd to directory wherewant to save
@echo off
setlocal enableDelayedExpansion
FOR %%q IN (%*) DO (
echo %%q
set locq=%%q
for %%F in (%%q) do echo %%~nxF
for %%F in (%%q) do set "testing4=%%~nF"
echo !testing4!
set play2=!testing4!
echo !play2!
:: set play2=!play2!.pdf%
:: echo !play2!
echo !locq!
gmt begin !play2!
::gmt grdimage !locq! -Jx1i/1i -I -B -pdf !play2!
gmt grdimage !locq! -Jx5i/5i -I -B
:: gmt psscale -Jx5i/5i -R!locq!
gmt psscale -Dx0c/-2c+w12c/0.5c+h
gmt end show
endlocal
The result isn't perfect as hard to set set of colorbar relative to the map. Here just batch script so can't adjust colours.
Outputs to pdf
