Setting the signal parameters of the Noran Ultradry detector.
Started by Ara, March 20, 2023, 07:01:46 PM
Ara
Please help me find instructions for setting the signal parameters of the Noran Ultradry detector. Too many trim resistors.
Sounds like a job for a service engineer or a factory technician.
On a modern detector, any user modifiable parameters are likely to be set through software.
Ara
What to do? ask the factory?
I thought this section was dedicated to hardware.
I also need a cable to connect the detector to the Noran System 7 unit. DB15-DB9. Or a diagram of such a cable for making it yourself. If you have a diagram please share.
SteveSeddio
Hello Ara,
For assistance with these issues, you should contact tech support.
I am not technically tech support, but I can get you in contact with the correct team.
Please contact me at stephen.seddio@thermofisher.com.
Alternatively, if you are located in the US, you can contact tech support here:
  (800) 532-4752
Select Option "2" For Tech Support
Then
Select Option "9" For EDS Support
-Steve
Ara
Hello Steve,
I wrote you an email.
Thanks for being willing to help me.
Ara
Ara
Hello everyone.
I still can't get the cable to connect the detector to the main unit.
Can anyone help me find the code for this cable? The code is needed to search the Internet.
In the figure, the cable is indicated by a red arrow.
Ara
In all likelihood, this is a custom cable built in house by Thermo.  A couple of alternatives suggest themselves:
  • maybe Steve Seddio or another Thermo service engineer can send you a schematic; or
  • you can find someone else with this system and they can test the connectivity of their cable to reverse engineer it.
Then you can buy the parts from Digikey or similar and build one yourself.
