Question on using the (manual) New project menus in CalcImage
Started by John Donovan, June 09, 2024, 01:00:35 PM
Do you ever use these (manual) add image files to project menus as shown below?
I always use the Create (new) Project Wizard menu in CalcImage to make new x-ray quant projects
I almost always use the Create (new) Project Wizard menu in CalcImage but once in awhile use the manual menus
I often use the manual add image menus in CalcImage
In the CalcImage application generally (almost always) one would use the Project | Create (new) Project Wizard menu to guide one through the process of creating a new CalcImage project for quantification of x-ray maps.
But in the beginning, we also implemented menus for manually creating a new project, selecting the PFE MDB file and sample for the x-ray map configuration including menus for manual adding maps to that manually created project as seen here:
Of course many of you found it easier to just edit a CalcImage CIP project file using a text editor which is just a simple text file with the extension .CIP as shown here:
10           "CalcImage Quantitative Image Project 6/3/2017 4:05:17 PM"
"Mg,Al,Gd,Sn,O_09-13-2012_Mg diffusion-2_00491_"
"Mg,Al,Gd,Sn,O_09-13-2012.MDB"
7             10            0             0             0            -1            -1            -1            -1            -1             0             0             0            -1            -1             0             0             0             0
0             5            .500           29.8959       29.8959       41276.4537384259            41276.4537384259           "Mg diffusion-2_00491_SP1_O_PC1_.grd"      0
0             2            .500           29.8959       29.8959       41276.453287037             41276.453287037            "Mg diffusion-2_00491_SP2_Al_LTAP_.grd"    0
0             3            .500           29.8959       29.8959       41276.4527083333            41276.4527083333           "Mg diffusion-2_00491_SP3_Gd_LLIF_.grd"    0
0             1            .500           29.8959       29.8959       41276.4521990741            41276.4521990741           "Mg diffusion-2_00491_SP4_Mg_TAP_.grd"     0
0             4            .500           29.8959       29.8959       41276.4515740741            41276.4515740741           "Mg diffusion-2_00491_SP5_Sn_PET_.grd"     0
1             5            .500           29.8959       29.8959       41276.4534837963            41276.4534837963           "Mg diffusion-2_00491_SP1_O_PC1__POFF.grd"               0
1             2            .500           29.8959       29.8959       41276.4530324074            41276.4530324074           "Mg diffusion-2_00491_SP2_Al_LTAP__POFF.grd"             0
1             3            .500           29.8959       29.8959       41276.4525                  41276.4525                 "Mg diffusion-2_00491_SP3_Gd_LLIF__POFF.grd"             0
1             1            .500           29.8959       29.8959       41276.4518981481            41276.4518981481           "Mg diffusion-2_00491_SP4_Mg_TAP__POFF.grd"              0
1             4            .500           29.8959       29.8959       41276.4513310185            41276.4513310185           "Mg diffusion-2_00491_SP5_Sn_PET__POFF.grd"              0
5
0  0  0  0  0
0
-1             0             0             0             0             0             0
0            ""
0             0
0            "VS1(BSE)"     0            "VS2(SE)"      0            "CL"
"Mg diffusion-2_00491_VS1.grd"            ""            ""
0             0
0             0             0             0             0             0
But now that the CalcImage new project wizard is so versatile we wonder if it's worth keeping these manual "load" menus around?   It's not a big deal to keep them, but we really don't have much more space for new menus, so if no one is using these menus we might consider getting rid of them.
What do you all think?   Please only respond to this poll if you've used CalcImage to quantify your x-ray maps as described here:
https://smf.probesoftware.com/index.php?topic=146.0
If you answered the poll with either answer 2 (I almost always use the Create (new) Project Wizard menu in CalcImage but once in awhile use the manual menus) or 3 ( I often use the manual add image menus in CalcImage), could you please provide a brief explanation of why you feel the need to use the manual add image menus in CalcImage?
Quote from: John Donovan on June 10, 2024, 12:23:55 PM
I answered 3: I often perform quantitative mapping on our JEOL using the JEOL PC-EPMA software as it controls both our SXES and JEOL EDS. In some cases - particularly light elements on the LDE crystals - I will make extra positions in the JEOL software for use as background maps. I will then convert everything using CalcImage into the Probe Image file format, and then add the backgrounds as required using the manual options.
