Error calculation: Save StrataGem/Badgerfilm output Format
Started by Ben Buse, June 24, 2024, 01:47:27 AM
How are the errors calculated for export to output format? When using average of datapoints for k-ratio what error is being exported?
is it standard deviation? is it count stats - and does that use assume multiple points homogeneous and treat as multiple points x time? i.e. standard error?
Ok it seems PFE does not export errors to badgerfilm/stratagem; with badgerfilm assigning a 5% error to each element
Would it be a good idea to export errors?
Quote from: Ben Buse on July 04, 2024, 08:23:30 AM
The STRATAGem format does not seem to support error values. I guess one could create a new field type but STRATAGem will never support it and it would be up to Aurelien to add this capability to BadgerFilm:
My take on users asking about errors in the thin film calculation is that at the very least one can simply propagate the relative variances display for the k-ratios in Probe for EPMA.  Here is a quick way to see the variances quickly in Probe for EPMA:
First click the Analyze! button, then click the KRaws button...  note the %REL SD output.
