Option to turn off event sounds?
Started by Dan R, July 23, 2025, 12:37:26 PM
Dan R
Is there a setting where we can turn off the event sounds from Probe for EPMA? Each time we use Remote to call 'unfreeze' it triggers an annoying 'Boing' sound and we'd like to turn this off. Is it possible to do without touching the windows settings?
-Dan
Quote from: Dan R on July 23, 2025, 12:37:26 PMIs there a setting where we can turn off the event sounds from Probe for EPMA? Each time we use Remote to call 'unfreeze' it triggers an annoying 'Boing' sound and we'd like to turn this off. Is it possible to do without touching the windows settings?
-Dan
You are referring to the "Beep" Windows API call I think.  I do not see any Beep calls associated with the UnFreeze command in our code.
You can change the "Beep" sound in the Windows settings.  Or turn down the volume...
Dan R
Thanks John, we'll check our code to see where that Windows API call is being made.
