Classify Image Exporter: image export option for CalcImage
Started by John Donovan, July 10, 2025, 07:02:57 AM
The latest version of Probe for EPMA (v. 14.2.3) has a new version of the Classify Image Exporter (v.1.2.1) for exporting maps as images in the CalcImage software:
In the new version Mia fixed a couple of minor bugs and improved support for wide or tall aspect ratio maps, by adding a separate field for the Y axis increment, for example as seen here:
Having separate controls for the X and Y axes allows for better graphics especially when the maps are very tall or wide as seen here:
Very nice, I'll have to give it a try. What controls the title font size?
Mia Kraft
Quote from: Ben Buse on July 10, 2025, 08:59:27 AMVery nice, I'll have to give it a try. What controls the title font size?
As it stands the font size is automatically sized and positioned based on the resolution and what I saw as similar to historical examples.
As Mia said, the Classify Image Exporter app auto sizes all text, but if you want more control over image fonts and sizes, you should use the Surfer output options:
https://smf.probesoftware.com/index.php?topic=55.msg509#msg509
Basically you output your maps using the Surfer script option, run the script BAS file, then locate the .SRF file for that export and open it in Surfer and manually edit your maps as desired.  Then export your images from Surfer.
