Running Ethereal on the JEOL UNIX computer
Started by Probeman, March 11, 2014, 04:12:23 PM
Is there a UNIX person out there that knows about running Ethereal on the JEOL UNIX box?
I believe that on the JEOL 8900 instruments, JEOL routinely installed the old Ethereal software, but not on the latest instruments. So I would be interested in any JEOL 8900/8200/8500 operators out there and if they have used Ethereal to capture any TCP/IP network communications on their UNIX box?
For example, Paul Carpenter asks:
1. Is Ethereal already installed on your Unix computer?  You will need to open a terminal prompt on the Unix computer.  The typical location on most system is:
/usr/local/bin/ethereal
It requires that you are "root" permissions in order to launch the program, so you will need to enter "su" at the command prompt to go to superuser mode...
Then you will need to cd to the bin directory:
cd /usr/local/bin
Then run Ethereal. Note, one can use full path to make sure it launches:
Anyone still out there with experience running Ethereal on the JEOL UNIX?
We have determined that Ethereal is already installed on the UNIX box of at least one JEOL 8500 (at WSU).
Thanks, Owen!
Normally I would use tcpdump to capture packages under unix/linux.
Gareth D Hatton
To find where it is installed (if not in the usr/local/bin)
find / -name "ethereal"
It may take a little while to churn through.
JEOL 8900 here and it is indeed installed. So, this is a network traffic analyzing tool? Are there any other nifty things that I can use it for?
