Default MAN
Started by Malcolm Roberts, August 11, 2014, 12:56:15 AM
Malcolm Roberts
The default is off peak, which I do not often use anymore. Which file should I dig around in and change so as to default to MAN?
Malc.
Quote from: Malcolm Roberts on August 11, 2014, 12:56:15 AM
There's no way to specify the default background type in the INI file (I think not anyway!), but the easiest thing is to simply load the setup from your last (or preferred) probe run and you will get all the background types specified there.
Malcolm Roberts
Makes sense. I dug around in the .ini file and couldn't find anything. just wondered if there was something in one of the others. Now... playing devil's advocate... I would say that it must have off-peak as the default somewhere? And then maybe the default can be changed somehow?
malc.
Quote from: Malcolm Roberts on August 11, 2014, 09:42:23 PM
Of course. Everything is *possible*.
But I'm leaving the bgd types initialized to zero which indicates off-peak (1 = MAN and 2 = multi-point-bgd).
But tell me this: once you have all your background types specified in a run, you can just keep reloading that previous configuration for every new run and you won't have to set anything manually, right?
Malcolm Roberts
That's true...but you presume I do this......... Some things call for other scenarios......
