JEOL PC-SEM Error Message
Started by Nuwan Sanjaya, October 27, 2014, 08:53:00 PM
Nuwan Sanjaya
I am using U-Th-Pb chemical maps of monazite to build a age map. but when I give the command to build the map I get following error message. (Field Emission EPMA JXA-8530)
Error Message
43: Note - A default dead time value is being used.
after this pop up message the software does not build the age map. How can I overcome this problem and what method or operations should I take...
Thank you in advance...
