Plot of wavescans and peak markers
Started by Philipp Poeml, November 27, 2014, 12:00:04 AM
I have a question about the wavescan plots. So, I choose some element, I make a peak search and this "calibrates" the wavescan, right? Now, it seems, that for this calibration the value in the xlines.dat is used. Could be 3.5 keV. Now, if I display peak markers for other elements in the plot, it seams, that the xray.mdb is used.
And now it comes: The values in xlines.dat and xray.mdb are sometimes way off. It took me a while to figure out. Because If I calibrate the spectrum on (example!) Fe Ka, the peak marker of Fe Ka would be off then. I already thought my spectrometers were broken. But then I realized that the two databases are not the same.
Any comments on this?
Philipp
Quote from: Philipp Poeml on November 27, 2014, 12:00:04 AM
Yes. Science is not perfect (or even self consistent)!
The XLINES.DAT file values are from Cal Tech.  The XRAY.MDB file values are from NIST. Maybe they should talk to each other?  ;)
Seriously, think of it this way- there is some disagreement in science, especially for the low energy emission lines.
Quote from: Philipp Poeml on November 27, 2014, 07:48:12 AM
... and M lines...
Yes, those too!
In fact it is even worse than that!  The datasets are not even "self-consistent". For example, if we look closely at the latest NIST x-ray database and compare the Mg Ka and Kb emission lines in MgO using a TAP crystal (not exactly high resolution), here is the full scan showing both Mg Ka and Mg Kb lines:
But is we zoom in a little, we can see that even the NIST database by itself, doesn't match the actual data as seen here:
Of course some of this discrepancy could be due to chemical states, and I don't have any (relatively unoxidized) Mg metal data to compare with.
