Iridium coatings in PfEPMA
Started by pgopon, September 22, 2015, 09:10:46 AM
pgopon
When I try telling the software that my samples are coated with 0.6nm of iridium instead of the default 20nm of C, is the software able to handle this?  I have noticed that the numbers are exactly the same (down to the third decimal place) if I process the data both with the C and the Ir coating.  This seems a little suspect to me.... but if the standards and the unknown have the same coating then maybe it is real?  Though or ideas?
Quote from: pgopon on September 22, 2015, 09:10:46 AM
The coatings you specify in the Standard menu (for standards) and the Calculation Options dialog (for unknowns) are there for documentation only- until you turn on the analysis options as described here:
http://smf.probesoftware.com/index.php?topic=23.msg1258#msg1258
pgopon
Wingo!! thanks John didn't have the use conductive coating for absorption/tranmission in analysis options checked.  Works now
phil
