Analyse vs Raw Data for TDI data
Started by Mike Matthews, April 23, 2016, 02:54:04 AM
Am I right in thinking that in the Analyze window the 'Analyze' button generates the TDI corrected concentrations and k-ratios, and the 'Raw Data' button outputs the counts and k-ratios uncorrected for TDI?
Quote from: Mike Matthews on April 23, 2016, 02:54:04 AM
You would be correct, sir!
You can also use this dialog from the Run menu for viewing the actual sub interval TDI data:
http://smf.probesoftware.com/index.php?topic=40.msg3970#msg3970
