Combined Conditions problem
Started by BenjaminWade, June 07, 2016, 05:48:24 PM
Hi John and all
I think I am going crazy. I was about to run some combined conditions runs but for the life of me can't figure out how to change the order of the conditions anymore. Didn't there used to be two little up/down arrows in the Combined Conditions window where you could move them up or down in the order? Is there some other way now to change the order the conditions are run?
Quote from: BenjaminWade on June 07, 2016, 05:48:24 PM
Hi John and all
You can't change the order of the conditions (I'm working on that!), but you can change the order of the elements.  Just put the elements you want to run first at the top of the sample element list in the Combined Conditions dialog.  The UpDown spin control is there.
I am feeling very stupid here. Can you show me where the spin control is? I have attached a screenshot of my combined conditions window...
Quote from: BenjaminWade on June 07, 2016, 06:07:22 PM
Use the Combined Conditions button from the Acquire! window...
Crap! I knew I was stupid. Thanks John...
Quote from: BenjaminWade on June 07, 2016, 06:18:24 PM
I probably should have a spin button in the Analyze! window Combined Conditions dialog as well, but I guess I figured you can't change the acquisition order for samples that have data!
Anyway, it should be there even if disabled for samples that have data, so I will add it.
You are too polite. You can outright say "you idiot, you are looking in the wrong spot!"
Thanks again.
