Remote COM Server documentation
Started by John Donovan, October 22, 2013, 09:24:44 AM
In case you are interested in trying out the Remote COM server for controlling your EPMA instrument by writing your own custom scripts, the download is here:
http://www.probesoftware.com/download/Remote.msi
Contact Probe Software if you need the login and password.
Documentation describing the available instrument functions that can be called from Excel, MatLab, LabView are described in the attached pdf. A number of examples are provided to get one started.
Edit by John: The Remote.pdf attachment has been updated.
The latest TestRemote installation msi package now contains the complete source code for compiling TestRemote.exe. Previous versions did not have the TestRemote.ico, TestRemote.rc and TestRemote.res files.
Download here:
Has anyone created a script for checking spectrometer count reproducibility when approaching at element from different directions and distances?
So measure peak and background position x10, when approach from 5mm below;
Then measure peak and background position x10, when approach from 5 mm above;
Then change to from 20mm below & 20 mm above
etc...
Quote from: Ben Buse on November 21, 2024, 03:13:00 AMHas anyone created a script for checking spectrometer count reproducibility when approaching at element from different directions and distances?
etc...
It should be easy enough to modify the TestReproduce.xls macro example that is installed with Remote.
Be sure to save it as a .xlsm file to a folder other than the application folder, though I've attached a renamed file below.
Netasp
The link is not working (http://probesoftware.com/ftp/Remote.msi), how to get the file (Remote.msi)?
Quote from: Netasp on December 08, 2024, 02:40:41 AMThe link is not working(http://probesoftware.com/ftp/Remote.msi), how to get the file(Remote.msi)?
This will work:
Also the links in the above posts are now fixed. Sorry about that!
Please note that the Remote interface will only work with Probe for EPMA.
Great I'm now using TestStability.xls in the remote folder
This bit of code doesn't seem to ever end loop, as counters never end together, - it only works with one counter.
' Wait for counts
alldone% = False
Do Until alldone
alldone% = True
For motor% = 1 To tunablespecs%
done% = tremote.RemoteGetCountStatus(fixedspecs% + motor%)
If Not done% Then alldone% = False
DoEvents
If ierror Then GoTo StabilityCountCancel
Next motor%
Loop
Any ideas?
I cheated and ran the loop until slightly longer than the count time, and stored the count intensity for each counter when done
Great to be able to run from code
It's great you can simulate it...
Just modified TestStablity so positionB is a random position within drive limits
Now need to try on instrument
Quote from: Ben Buse on January 08, 2025, 04:42:25 AMGreat I'm now using TestStability.xls in the remote folder
' Wait for counts
alldone% = False
Do Until alldone
alldone% = True
DoEvents
Next motor%
Loop
Any ideas?
I don't know. The TestStability app seems to run OK on my computer in simulation mode.  See attached image.
The only thing I can suggest is to maybe add some short delays in the loop.  Do Excel macros support say, the Sleep system call?
I did note that the macro seems to count 10 seconds on the first cycle when it should count 20 seconds, and then it seems to throw that data away, but then it proceeds fine with the remaining cycles.
Probably an initialization issue in the macro code, but I'm sure you can figure that out!
You must copy all Excel files from the C:\Program Files (x86)\Probe Software\Remote folder to another folder that is not write protected, in order to run or edit them.
I would also save these older Excel files to their new Excel macro file extensions: *.xlsm
The latest Remote server documentation is attached below for v. 14.2.2
