K-ratio extrapolation and saving bug
Started by Walter, March 21, 2017, 06:36:43 AM
Walter
Hello,
I was wondering if it was possible to know more deeply how DTSA-II extracts the k-ratios for the quantification using the sample spectrum and standards. Because i'd like to calculate k-ratios by hand for some spectra but I can't obtain the same results.
I've also another issue: I've wrote a script to simulate a batch of spectra, I'd like to save them automatically but the command "saveSpectra" doesn't seem to work, maybe there is a problem with ":". There is an alternative way to save and to avoid having more than 50 spectra unsaved open?
Thank you
Hi Walter,
Below is an example of a script that batch simulates films on substrates and saves the spectra. For K-ratios think it uses complex peak deconvolution and peak shape fitting so it would be hard to replicate.
The save command is
         resF[fil].save("%s/%s.msa" % ( pathloc, resF[fil] ))
where pathloc is given a few lines up
import dtsa2 as dtsa2
test = {}
volt = 15 # accelerating voltage
det = findDetector("Si(Li)") # Replace with your detector's name
nE = 1000 # Number of electrons simulated
e0 = volt # kV using volt loop - 1st 15kV, then 10 kV
rhoAg = 10.49
# create materials
sAg = epq.Material(epq.Composition(map(dtsa2.element,["Ag"],),[1],"Silver"),epq.ToSI.gPerCC(10.5)) #ToSi converts density g/cc to kg/m3, composition as mass fraction
s316H = epq.Material(epq.Composition(map(dtsa2.element,["Mn","Cr","Mo","Ni","Fe"],),[0.016,0.169,0.022,0.119,0.667],"316H steel"),epq.ToSI.gPerCC(7.8))
# calculate electron range for one of the materials - determining range of x-ray emission images and phi-rho-z
range = dtsa2.electronRange(s316H,e0,density=None)
# set xray transitions
trs = [epq.XRayTransition(epq.Element.Ag, epq.XRayTransition.LB1),
epq.XRayTransition(epq.Element.Fe, epq.XRayTransition.KB1)]
# create samples consisting of silver film on steel (316H) substrate
film = {}
film[1] = [sAg, 0.000000020],[s316H, 0.000010] # 0.000005000 = 5 um 0.000010 = 10um Configuring multi-layers composition and thickness
film[2] = [sAg, 0.000000015],[s316H, 0.000010] # 0.000000050 = 0.05 um
film[3] = [sAg, 0.000000010],[s316H, 0.000010]
xtraP = {}
xtraP = {"Characteristic Accumulator":True, "Char Fluor Accumulator":True, "Brem Fluor Accumulator":True}
xtraP.update(mc3.configureOutput(DefaultOutput))
xtraP.update(mc3.configurePhiRhoZ(1.5*range))
xtraP.update(mc3.configureEmissionImages(trs, 1.5*range, size = 512))
xtraP.update(mc3.configureTrajectoryImage(1.5*range, size = 512))
resF = {}
for fil in film:
extension = str(film[fil][0])
extension = extension.replace("[","")
extension = extension.replace("]","")
extension = extension.replace(",","")
pathloc = 'O:\Documents\PFE_Data\Users\Charles_Younes\\041115_CarbonInSteel\\dtsa2repeat7_' + extension # Change to output folder
xtraP.update(mc3.configureOutput(pathloc))
print xtraP
resF[fil] = mc3.multiFilm(film[fil], det,e0=e0, nTraj=nE, dose=500.0, sf=True, bf=True,xtraParams=xtraP) # run simulations
tmp = str(resF[fil])
tmpx = extension + tmp
resF[fil].rename(tmpx)
resF[fil].save("%s/%s.msa" % ( pathloc, resF[fil] )) # change pathloc above to output folder ( location, name) it adds extension
resF[fil].display()
Walter
Thank you for your answer!
Your code is much more complicated than mine, i don't even know a lot of commands that you have used, I'll study on it for a while. Here I've reported one of my typical scripts.
Ta=material('Ta',16.65)
Au=material('Au',19.32)
SiO2=material('SiO2',2.5)
thk1=[20e-9,70e-9,120e-9,170e-9]
thk2=[100e-9,150e-9,200e-9,250e-9,300e-9,350e-9]
for i in range(len(thk1)):
    for j in range(len(thk2)):
        lyr=[(Au,thk1[i]),(Ta,thk2[j]),(SiO2,1e-5)]
        mc3.multiFilm(lyr,d2,e0=25,withPoisson=False,nTraj=1000,dose=60.0,sf=True,bf=True,xtraParams={}).display()
        print('%d of %d' % (len(thk2)*i+j+1,len(thk1)*len(thk2)))
print('end')
Anyway I've tried to use the command  spectrum.save(path) but the results don't change: if I use
s1.save("C:\s1.msa")
or
saveSpectra(s1,'C:\s1.msa')
turns out the same error
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File "C:\Users\Walter\AppData\Local\NIST\NIST DTSA-II Jupiter 2016-05-24\Lib\dtsa2\__init__.py", line 339, in save
    os = jio.FileOutputStream(filename.replace(":",""))
at java.io.FileOutputStream.open0(Native Method)
at java.io.FileOutputStream.open(Unknown Source)
at java.io.FileOutputStream.<init>(Unknown Source)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at org.python.core.PyReflectedConstructor.constructProxy(PyReflectedConstructor.java:211)
java.io.FileNotFoundException: java.io.FileNotFoundException: C\s1.msa (Impossibile trovare il percorso specificato)
maybe there is an issue in the version that I'm using (the latest), on which version do you run the script?
For the K-ratio basically should be the ratio between the integral with the background stripped between the sample and the standard, right? I'd like to extract in the K-ratio in Origin for some spectra simulated with pyPENELOPE (to make some comparison between the softwares) that are spike like and the quantification of DTSA-II doesn't recognise as spectra.
Walter
Hi Walter,
I don't known. In Iona resF[fil].save('.msa') works. As does saveSpectra()
Regarding k-ratios why don't you calculate both dtsa-2 and pypenelope spectra by hand using same method so that comparable. Its a ratio to standards so as long as you do the same on unknown and standard you'd expect to get the same value.
There are several methods of k-ratios
On WDS its peak height - background height
EDS I don't know much about but on EDS can by integral under peak minus background. But can also use peak devolution and peak shape fitting. - But this should just remove contributions from overlapping elements.
Do you have PFE? John has now included spectra simulation based on PENEPMA which pypenelope uses - but then does some form of peak broadening to make them realistic. You could then import into dtsa-2.
Walter
Ok, therefore it's a bug release for sure. On NIST website it's only possible to download the latest version, do you have a link to download previous versions?
I'll try the method that you suggest for k-ratio calculation, I hope to obtain the same values and then, after ZAF correction, the same quantification.
I'm a little abashed, What PFE stands for?
Is something correlated to CalcZAF? or maybe is the program that Philippe Pinard (pyPENELOPE developer) told me about "There is a Fortran program distributed with Penelope That can apply a convolution over the x-ray spectra." but then never reply to me again? or even something else?
Anyway, I really appreciated your help, thank you a lot!
Hi Walter,
The peak broadening program is convolg and it is shipped with the version of Penepma that comes with CalcZAF.
PFE is Probe for EPMA - software to drive a microprobe - it is distributed by Probe Software - of which CalcZAF is a free EPMA utility package. See here for PFE spectra simulations:
http://smf.probesoftware.com/index.php?topic=837.0
regarding convolg
http://smf.probesoftware.com/index.php?topic=837.15
And paper
PENEPMA: a Monte Carlo programme for the simulation of X-ray emission in EPMA
X Llovet1 and F Salvat2
"A simulated X-ray spectrum corresponds to an ideal detector, and hence, characteristic lines are
very narrow, i.e., each line is fully contained in a single channel of the output histogram. In order to
obtain a realistic spectrum, which can be compared, e.g., to an experimental spectrum, the effect of the
finite energy resolution of the detector must be introduced. The PENEPMA package contains a Fortran
programme called CONVOLG that performs this calculation by assuming that the energy-resolution
function of the detector is a Gaussian with energy-dependent full-width-at-half-maximum."
jrminter
Walter, below is a reproducible example that works with the current version (Jupiter). The simulation uses the wrapper class provided by Nicholas Ritchie. Take a look at the file "mcSimulate3.py" in the DTSA_Dir/Lib/dtsa2 directory. It has lots of useful functions. The last two lines show how to correctly write a .msa file.
Best regards,
John
# minimal repo example
# Answer for walter on Probe forum
import gov.nist.microanalysis.EPQTools as ept
import java.io as jio
import os
import glob
import shutil
e0 = 20.
nTraj = 1000
dose = 60.
addNoise = True
outDir ="C:/Temp/"
ag = material('Ag', 10.49)
spc = mc3.simulate(ag, d1, e0, dose, addNoise, nTraj, sf=True, bf=True, xtraParams={})
sName = "Bulk-Ag-%g-kV-%g-Traj" % (e0, nTraj)
spc.rename(sName)
spc.display()
fos = jio.FileOutputStream("%s/%s.msa" % (outDir, sName))
ept.WriteSpectrumAsEMSA1_0.write(spc,fos,ept.WriteSpectrumAsEMSA1_0.Mode.COMPATIBLE)
The save bug was introduced in an early version of DTSA-II Jupiter and has been fixed in more recent versions.
The problem is in the Python class ScritableSpectrum function save(...) in the file "lib\dtsa2\__init__.py" which is executed every time DTSA-II starts up.
The corrected code is as follows:
    def save(self, filename):
        """s.save(filename)
    Write this spectrum to an EMSA 1.0 format text file."""
        os = jio.FileOutputStream(filename[0:2] + filename[2:].replace(":", ""))
        ept.WriteSpectrumAsEMSA1_0.write(self.wrapped, os, ept.WriteSpectrumAsEMSA1_0.Mode.COMPATIBLE)
        os.close()
The 2017-Feb-17 version on the NIST web site has this fix.
