New NIST DTSA-II user with QUESTION...
Started by Amedeo, October 25, 2017, 01:15:16 PM
Amedeo
Hello,
I just recently downloaded DTSA-II from NIST.  I have (I believe) a simple simulation I would like to run, but cannot seem to pull it out from DTSA.  Maybe someone can help me, or recommend another approach.
Question:  I want to show a simulation which tests whether Fluorine can be detected under 100Å of SiO2 using 5 kV.  As a follow up, I would like to plot that as a function of oxide thickness and ideally take-off angle.  For the fluorine, assume a buried 20Å film of PTFE.
Many thanks for any help!
Amedeo
And all this science, I don't understand.
It's just my job, five days a week.
Hi Amadeo,
I can't speak to DTSA, but if you have downloaded CalcZAF you can easily generate a spectrum and intensities for a thin film model and a standard using the Penepma Monte Carlo software that it comes with:
http://www.probesoftware.com/download/CalcZAF.msi
A tutorial and examples are found here:
http://smf.probesoftware.com/index.php?topic=57.0
On a more crude basis one can simply calculate the absorption of F Ka in SiO2 using the Model Electron and Xray Ranges dialog in CalcZAF as shown here:
http://smf.probesoftware.com/index.php?topic=86.msg309#msg309
Look under "Tools > Simulation Alien".  The dialog will step you through the process.
