Latest version changes for Probe Image v. 1.5.4
Started by John Donovan, November 21, 2013, 05:39:04 PM
What's New
Version 1.5.4 - 23-February-2026 - Aurelien Moy
New Feature
  - Add an Update button in the Acquisition dialog.
Bug Fixes
  - Fix GRD export plugin.
  - Update Copyright information.
Version 1.5.3 - 4-February-2026 - Aurelien Moy
Bug Fixes
  - Prevent stage coordinates X2 and Y2 from rounding to invalid values.
  - Fix a bug with negative values for stage coordinates.
  - Use a geometric average for the Z coordinate when clicking the "Move Center" button in "Stage 2Pt" mode.
  - Fix a bug where the vertical scrollbar does not work properly when managing the acquisition sample list
Version 1.5.2 - 16-December-2025 - Aurelien Moy
Bug Fixes
  - Fix rounding issues with stage step size when using Stage 2Pt on CAMECA instruments.
  - Limit the maximum number of pixels to 5120 per axis.
Version 1.5.1 - 13-November-2025 - Aurelien Moy
New Feature
  - Revert the maximum map size to 2048 x 2048 pixels for JEOL 8X30 instruments.
  - Limit the total number of pixels to 2048*2048 and the X and Y dimensions to 32k pixels each.
Version 1.5.0 - 16-October-2025 - Aurelien Moy
New Feature
  - Change the maximum map size to 4096 x 4096 pixels for JEOL 8X30 instruments.
  - Remove the EDS Inputs panel in the Scan Setup window for JEOL 8X30 instruments.
Bug Fixes
  - Fixed a bug in Demo mode where Cameca behavior was always enabled for map size and minimum step size.
Version 1.4.15 - 07-September-2025 - Aurelien Moy
Bug Fixes
  - Included corrected numbering version of ConvertToPrbImg.exe to version 14.2.4.
Version 1.4.14 - 02-September-2025 - Aurelien Moy
Bug Fixes
  - Reverted Set Magnification function to EIKS call for JEOL 8X30 instruments.
  - Updated ConvertToPrbImg.exe to version 13.9.0.2.
Version 1.4.13 - 01-July-2025 - Aurelien Moy
Bug Fixes
  - Added verbose log information in the Set Magnification function.
Version 1.4.12 - 17-June-2025 - Aurelien Moy
Bug Fixes
  - Add EOS STATUS structure in amb jeol8x00 driver definition to fix bug with new direct TCP/IP call for magnification get/set for J8x30 instruments.
Version 1.4.11 - 01-June-2025 - Aurelien Moy
Bug Fixes
  - Fix bug with new direct TCP/IP call for magnification get/set for J8x30 instruments.
  - Fix bug in verbose log about current spot mode.
Version 1.4.10 - 10-May-2025 - Aurelien Moy
New Features
  - Add direct TCP/IP call for beam current read and magnification get/set for J8x30 instruments.
Bug Fixes
  - Fix bug with incorrect acquisition end date.
Version 1.4.9 - 06-March-2025 - Aurelien Moy
Bug Fixes
  - Updated copyright.
  - ConvertToPrbImg.exe updated to version 13.9.0.2 from Jan-9-2025.
Version 1.4.8 - 05-November-2024 - Aurelien Moy
Bug Fixes
  - File names are checked to remove invalid characters.
  - ConvertToPrbImg.exe updated to version 13.9.0.2.
Version 1.4.7 - 28-May-2024 - Aurelien Moy
- Fix negative stage positions bug when entered by keyboard.
Version 1.4.6 - 07-December-2023 - Aurelien Moy
New Features
  - Included an EDSSynchMapName field in the prbimg file to record the synchronized EDS map file name.
  - Included a ProbeImageVersion field in the prbimg file to record the version of Probe Image used to create the file.
  - The prbimg file format version is bumped to 1.3.0 because of the new fields added to file.
Bug Fixes
  - Removed duplication of EDS saving SI data message in verbose mode.
  - Clarified an error message about the image size presets.
  - Corrected a bug in the Bruker plugin where after closing the communication with the DLL, a variable was not set back to 0.
Version 1.4.5 - 06-December-2023 - Aurelien Moy
Bug Fixes
  - Corrected a bug where the naming of the maps was inconsistent when using TDI replicates and/or EDS spectrum acquisition.
  - Renamed the EDS Spectrum Acquisition from "EDS Channel" to "EDS Synchronized Spectrum Acquisition".
  - Display EDS plugin error messages in the log window even if not in verbose mode.
  - The Faraday cup is now retracted after the EDS communication is established.
  - The Faraday cup is now inserted before the EDS communication is terminated.
Mike Spilde
How often should one update the Matrix COM server? Should it be down loaded each time I download and update Probe Image?
Quote from: Mike Spilde on October 28, 2014, 01:52:18 PM
The Matrix COM server interface is used for certain configuration information and is pretty static these days.  So I wouldn't worry, but updating it will not hurt.
If I do make a change requiring an update to Matrix, I will post it to the forum very visibly!
Probe Image no longer utilizes the Matrix COM interface. The instrument crystal configuration is now read from the Scalers.dat file in the Probe for EPMA app folder as seen here in the Probe Image Probe Setup dialog:
If you would like to discuss the Matrix COM server itself, for use in accessing all CalcZAF matrix correction physics models, including Penepma derived polynomial alpha factors, please see this board:
http://smf.probesoftware.com/index.php?board=8.0
Hi All,
just a note to backup your probe epma directory when installing probe iamge 1.2.2.1984. I installed it last week and it deleted probewin.elm, probewin.pha and scalers.dat files. Fortunatly following one of John's earlier v11 posts i had backed up the Probe for Epma directory and was able to copy them back in.
Quote from: Ben Buse on October 19, 2015, 01:56:10 AM
Hi All,
I don't think it deleted them, it just didn't find them in the folder it was expecting them in.  Remember PFE moves those files in the old PFE folder to the new PFE folder: C:\ProgramData\Probe Software\Probe for EPMA.
In Probe Image, if you check your Default Paths section under the Setup | Probe Image Setup menu dialog, you should change the .ELM, .PHA and SCALERS.DAT paths to:
I understand now you've split the program into two parts part of which goes in program files directory and part of which goes in program data directory - so for these files it now needs to look in program data directory.
Quote from: Ben Buse on October 20, 2015, 05:13:02 AM
That's how Microsoft wants it!
I note that PI has some bugs when using Concatenate Image | Mosaic. (GRD files)
I have a 3x3 grid of images. If I add the first 3 images in X direction (0,0) (1,0) (2,0)  PI will mosaic the images. If I add the second row (0,1) (1,1) (2,1) and try to mosaic the 2x3 grid, PI will stop working with message "A problem caused the program to stop working correctly" etc.
I thought I had read that this was fixed, but since this is version 1.2.2.1984, doublethink will be applied.
Gareth
Quote from: Gseward on November 29, 2015, 01:54:59 PM
Gareth
Hi Gareth,
I thought so too.
Can you send Brian the images as a ZIP and cc me also?
In the meantime just use Surfer to concatenate them...
Malcolm Roberts
Can PI be updated to include the pixel dimension used in a run to the information on beam I, dwell time and etc. I can get at this the long way around, but as we are specifying this during the run set up, it would be good to have this attribute added to the information.
malc.
Quote from: Malcolm Roberts on November 29, 2015, 04:56:43 PM
malc.
Brian is adding this information to the PrbImg file as we speak...   ;D
The latest version of Probe Image now allows the user to specify beam current (in addition to keV and beam size) for each x-ray map acquisition sample for Cameca SX100/SXFive and JEOL 8230/8530 instruments.
Thanks to Philippe Pinard for his 8230/8530 help on this.
The latest Probe Image has improved code and a simpler GUI for setting the beam mode for JEOL 8900 instruments.
Download from here:
If you need assistance please contact Probe Software.
Glenn Poirier and Gareth Seward have been working with Brian Gaynor testing the new crystal flipping code in Probe Image and it all seems to work now. This update should only affect JEOL 8230/8530 and Cameca users with large area crystals, that need to flip crystals before or during x-ray map acquisition in Probe Image.
Yes, normally one should probably not flip crystals just prior to acquiring quantitative x-ray maps, but it could happen, so we wanted to get that fixed.
Basically we needed to add a delay between sending the flip crystal command and when we start checking the crystal flip status for the new JEOL instruments, and for Cameca instruments, we didn't have the correct indexing for large area crystals (yes- it's different!).  It's always worked in PFE, but somehow we overlooked that in PI.
If you have Probe Image please feel free to download this latest installer using the download link here:
https://www.probesoftware.com/download/PI-Update.zip
