ROM peaking for Post-Scan
Started by JohnF, January 31, 2015, 05:42:33 AM
JohnF
How do you "turn on" the greyed out 'use rom peaking' for the _post-scan_ option in Peaking?
Quote from: JohnF on January 31, 2015, 05:42:33 AM
Sorry, that is an oversight that is easy to fix.  It should "enable" if either of the Pre/Post options are checked.
In the mean time there are several other places to toggle that option as it is a global. Here's one:
I will upload a new version today anyway.
This option is useful for super fine adjustment, but now there's a better way to manually adjust the exact peak position by using this feature:
http://smf.probesoftware.com/index.php?topic=42.msg473#msg473
after the peaks have been peaked. In other words, from now on you can just skip the pre/post peak scans and use the mouse from the Run | Display Peak/ROM Scans menu.
Fixed enable is ready to download (PFE v. 10.6.9)
