Processing Capabilities of Probe Image
Started by cvidito, April 08, 2015, 11:18:12 AM
cvidito
Does Probe image have the ability to add elemental maps? For instance if I were to map the same trace element on multiple spectrometers could I add them all together to produce a single, higher quality map? Also, can the software do ratio maps or even calculate An# or Fo# maps? Thanks.
Chris
Quote from: cvidito on April 08, 2015, 11:18:12 AM
Chris
Hi Chris,
Yes to all.
Re-processing of raw intensity maps acquired by Probe Image for background, matrix and interferences is performed in our CalcImage app. Here is a aggregate intensity mapping feature in CalcImage:
http://smf.probesoftware.com/index.php?topic=41.msg2181#msg2181
and here is the end-member map quant in CalcImage also:
http://smf.probesoftware.com/index.php?topic=41.msg195#msg195
See the 2nd attachment for a feldspar end-member quant map (you'll need to be logged in to see attachments).
and here are formula maps:
http://smf.probesoftware.com/index.php?topic=41.msg196#msg196
I'll be adding in the ability to perform image math in CalcImage using a user specified formula in the next month or so...
